跳转到主内容
Power button/novo button turns on laptop, blinks once, then turns off
The laptop suddenly stopped working. Things I have tried:
  1. Removed the main battery and press and holding the power button for 30 seconds.
  2. I tried to find RTC battery but this model doesn't look to have one? I'm not sure
  3. I tried to disconnect other cables to the motherboard and press the power button for 30 seconds.
Another weird thing is that afterwards when you press the Lenovo vantage button with the star and s (after f12) it acts as a power button and does the same thing. It turns off afterwards. It all started with some windows 11 update, it probably updated the BIOS then it also broke the speakers. I did a clean install thinking it was the drivers. Still didn't work. Then I checked the speakers with 12v battery and it was responding. It was working then just without the speakers. But now it wont turn on both with power and novo. Does anyone have the same issue and fix? Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
You don't mention if you removed the hard drive. Try that and see if you can get into the BIOS/UEFI utility by repeatedly pressing the F2 key.
IdeaPad 5 Pro Service Manual
Since your problem started with a Windows 11 update the above sounds like a good place to start.
这个答案有帮助吗?
得分 2
6条评论:
Thank you Mike! I tried removing the ssd and the WiFi too but no luck. I wonder if the motherboard is fried.
完成的
Hi @j4laptopfix
I don't think a Windows update would fry the motherboard. Have you tried disconnecting the battery (page 29 in service manual) and just plug in the charger?
完成的
Ah I see. Yes! I have tried unplugging the battery and just the charger. It still does the same thing unfortunately. Do usb c hub fry motherboards?
完成的
@j4laptopfix "Do usb c hub fry motherboards?" Not that I know of.
I just reread ypur initial question. Could you explain what you actually did "Then I checked the speakers with 12v battery"? Which speakers? What 12V battery? You have me worried.
完成的
My bad! I used a 9v battery to see if the speakers work and it reacted to the 9v so I thought that speakers were still good. I then used the laptop again with the usb hub with the power plugged in the hub so now I’m thinking it must be the usb c hub that broke the motherboard.
完成的
显示更多的1条评论
添加一条评论
添加你的答案
j4laptopfix 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 55
总计 55
