跳转到主内容
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
20 个问题 查看全部
I can’t open the shell
Inside the system, there is some damage that leads to the touch screen not working. So I decided to open the console but, due to the fact that I bought the system a long time ago and second hand, the screws were broken which made it impossible to open. I don't know if I should break the shell but I don't want to damage the system.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You mean the screw heads are stripped? If so there's an old trick that some times works. Take something like a rubber band, place it on the screw head then press the screwdriver into the rubber band. The idea is the rubber band can in some cases compensate for some of the lost/stripped material. If this works, get new screws before reassembling to make life easier in the future.
If the worst case scenario happens and you have to break the shell, do it carefully so that you only break the backside part. Those can be more easily replaced.
这个答案有帮助吗?
得分 0
1条评论:
Two things I'd like to add to this. First, iFixit does actually have a guide (如何卸下滑丝的螺丝) on removing stripped screws. Second, try a piece of fabric instead of a rubber band. It's a trick I picked up from the comments on that guide, and I find it works much better
完成的
添加一条评论
添加你的答案
José Francisco Mendes Pires 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 36
