MacBook won’t boot after battery replacement
Hi-I replaced the battery on my MacBook Pro and it will not boot up. The battery level comes up on the screen when I plug it in, but it will not boot. Any help would be greatly appreciated!
If you see the battery icon on the screen in either a charging or charged state then we know the power is getting to the battery from the charger and it should finish charging.
The fact the power button is not responding implies the power button connection to the logic board is not secured or is damaged. Review Step 31 in this guide 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换
这个答案有帮助吗?
@Dan-That did it! Always something small/simple. Thank you!!
@mccrocketman - Happy Days! Please don't forget to score the answer and accept it, if you are set - Thanks!
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 43
总计 43
