My purifer unable to fill water in its tank?...why?
Likely calcium build up in the lines.
If you can, push a straightened metal coat hanger thru the fittings and pipes or use a calcium cleaner within a bucket to soak the fittings and pipes. Make sure to fully rinse off the cleaner from the parts and let the water run a bit before using.
这个答案有帮助吗?
过去 24 小时: 4
过去 7 天: 5
过去 30 天: 14
总计 50
@sehajarora80537 let us know if you have a make and a model for this. You also want to post some pictures of your setup. Let's see what you got going on there. 在已经存在的问题里加入图片
Mine uses a prefilter that require frequent changing. I clean mine every 3 months of use with food grade citric acid.
由 oldturkey03 完成的
