跳转到主内容
Repair and disassembly guides for Epson printer. The company was founded in 1942 as Daiwa Kogyo, Ltd., but merged with another company in 1959 to create Suwa Seikosha Co., Ltd.
624 个问题 查看全部
Epson aculaser C1700 refuses to print any page past the first?
I got this printer yesterday. So it is new, out of the box. I connect it with the USB cable on a Pentium 4 Windows XP and plenty of ram and want to print a document.
No matter what I do, install drivers, uninstall and reinstall from the internet, the printer prints the 1 page of any document and then paper jams on the second.
It has no problem printing 1 page documents. But if it is multiple page doc, pdf, internet page, it jams on second page.
So the question obviously is what is going on?!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
check correct paper size!
这个答案有帮助吗?
得分 0
1条评论:
Of course there are, but I would think that A4 is global default more or less.
完成的
添加一条评论
最有帮助的答案
It seems that the printer had as paper input some sort of Letter dimensions. Once this was changed to A4, it started printing normally (after frustrating me to the max). Also under windows 7, there is a pop up message indicating that the paper size is wrong, on windows xp though such a message didn't pop up making my life difficult. So it seems that changing the default paper size solved the problem. However epson could be a doll and fix this problem by assuming that the default paper size is A4 rather than something else
这个答案有帮助吗?
得分 2
2条评论:
good job in getting it done. Since Epson is a worldwide company and there are countries that use different paper sizes, as well as users using different sizes of paper, I don't foresee A4 as a default. ;)
完成的
Thanks for the excellent advice!!! Was absolutely frustrated that could not get past page 2, now it works! Simply changing to A4, who would have thought something so small could hold everything up
完成的
添加一条评论
添加你的答案
nikosap 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 2,389
