跳转到主内容
加入维修社区 - 创建账户
DualShock 4 CHU-ZCT2U 的维修指南、手册和故障排除帮助。获取自己维修 DualShock 4 CHU-ZCT2U 所需的一切。
Why are my trigger buttons triggering when I squeeze the controller.
So I have a controller that’s a few years old, recently broke out the old ps 4 pro and wanted to play a few games with it. Every time squeeze the controller firmly or hard it weirdly sets off the trigger buttons (L2/R2). And sometimes it just gets stuck that way. Also noticed that press down on the analog sticks can just set them off too. Tried resetting it and taking it apart to blow some air around inside it to clean it up a little. Still the same problem. Does this mean the controller is completely broken or is there a way to fix this sort of problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi!
This is a weird issue! I recognize the issue, when pressing down on the analog sticks, it triggers the L2/R2 buttons. I solved this with replacing the analog sticks. Be aware that this will require soldering.
Here is a guide so you can determine if you want to do the repair or not.
DualShock 4 Right Analog Stick Replacement (this is for the V1 controller, but the process is nearly the same).
Good luck and let us know how it goes!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Tratis Scott 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 187
