跳转到主内容
Repair information and guides for the updated version of the 2015 Retina MacBook that was released in early 2016. Model A1534 / EMC 2991
Mac slows drastically after battery change
I just changed the battery on my Mac following this guide. After I changed the battery, I somehow tore the Retina display cable. I replaced that as soon as possible, and then calibrated the battery. Now that the Mac is up and running again, it is so slow! Even after wiping the drive and reinstalling a copy of macOS from Internet Recovery, the Mac is so slow. I feel like the Mac may be rejecting the new battery by lowing its performance. Is this a common issue with batteries that are not by Apple?
Here are the pictures from coconut battery:
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
Lets get a better view of things install this gem of an App CoconutBattery, take a snapshot of the Apps main window and post it here for us to see.
完成的
@danj - I will... but I can't right now. Unfortunately I am away from my Mac at the moment. In about a week or so I will get it back.
完成的
Hey everyone. Sorry for the delayed response. I still haven't gotten back to my Mac. But, it looks like next Saturday I should have an answer. Thanks for your patience!
完成的
添加一条评论
2个答案
已选择的解决方案
Hi Jadon,
It's a known behaviour that MacBooks throttle when the battery is removed or it doesn't recognize the battery (see this Apple doc dating back to 2008). However, considering that you calibrated the battery, it looks like the MacBook recognizes the battery. The first thing you should probably try is resetting the SMC.
这个答案有帮助吗?
得分 4
4条评论:
Hey there! Thanks for the insight! I can’t remember if I reset the SMC or not… so I will definitely check into that. Like I said, though, I am out of town at the moment and away from my Mac. In a week or so I will be back. But thanks for the suggestions!
完成的
Hi Jadon,
I would advise you do this seeing as your battery condition is good.
完成的
@arandomhitman - Okay, I just did the SMC reset, and that changed the speed drastically. I am shocked. I usually always reset the NVRAM and SMC after any change I do to a Mac… I guess I completely forgot this time. Anyway… I’ll keep using it for a while… but as far as I can tell, that fixed the problem. Thanks for you help!
完成的
no problem, glad it worked.
完成的
添加一条评论
Hi Jadon,
Due to the nature of Apple, I wouldn't put it past them to do such a thing.
However, would you mind installing coconut battery on your device and sending a screenshot of all the statistics shown?
这个答案有帮助吗?
得分 0
3条评论:
完成的
@jadonlyon no problem.
完成的
@arandomhitman - Hey there. I apologize for such a delayed reply. I've got the screenshots from coconut battery.
完成的
添加一条评论
添加你的答案
Jadon Lyon 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 55
总计 442
