跳转到主内容
Why is my MacBook typing letter "r" all by itself?
Hi all, my Macbook Pro recently started typing the letter "r" continuously regardless of what program I was in. I can delete them as they are typing but then after a few seconds it will start again. When I am out of all programs and just the desktop is visible the computer makes a noise as if it is trying to type it again. Do you think this is a keyboard problem? I would appreciate any suggestions.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
2条评论
I have this exact same problem. I did clean under my R key but this did not fix the issue? Did you solve it?
完成的
My problem was caused by the battery swelling up. This caused issues with the keyboard. After replacing the battery ($150) and the keyboard ($100) this solved the issue.
完成的
添加一条评论
5个答案
已选择的解决方案
Yes, this is a keyboard problem. Pop the cap off the R key and see what sticky stuff is holding the key depressed and clean it off. Wet your cleaning cloth lightly first. Never spay any cleaner directly onto your machine.
这个答案有帮助吗?
得分 7
5条评论:
Thanks Mayer, there was something under there but, and I feel silly for asking this, but is there a trick to getting the cap back on?
完成的
Mayer, disregard last question - found a how-to video on Youtube. Letter 'r' problem all fixed. Gotta love the internet! Thanks for your help.
完成的
UR welcome, come back any time ;-)
完成的
it doesnt work
完成的
the problem still occur even after I cleaned up under the cup. pleas help! :(
完成的
添加一条评论
If you got a mouse connected remove it end restart and get a new mouse that mite be the problem
because that is the problem that i had once
这个答案有帮助吗?
得分 1
添加一条评论
Mine requires more pressure on the r key than the est.
这个答案有帮助吗?
得分 0
添加一条评论
i have the same exact problem with my ‘N’ key. it’s missing off the laptop keyboard, so i have to use an external keyboard, but it won’t stop doing this even still, so any answer will be gladly appreciated.
这个答案有帮助吗?
得分 0
添加一条评论
Cleaning the key does not solve the problem for me... unfortunately the ghost typing continues. At the same time, like Lancecharles, it's hard to get the letters to print when I want them (the i and u in my case). The ghost tho will type i's and u's (with accent) at random or stream them until I hit escape.
Like Lotusjohn, i'm using an external keyboard. I just plopped a bluetooth ontop of my mbp with a couple plastic rulers as separating platform between the boards.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Julie 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 29
过去 30 天: 143
总计 22,541
