跳转到主内容
Xbox Series X 是微软公司次时代4K游戏主机。2020年11月10日,Xbox Series X与其配套主机Xbox Series S一起发布。
What part of the xbox series x handles wireless controller connecdion?
what part of the xbox series x handles wireless controller and headset connection? My Xbox Series X keeps disconnecting my controllers and headsets. I've tried every single suggested fix I could find. The only thing I can think of now is putting a new part in it. I just don't know what the official part is or how to get it.
Would it be better to take it to a repair place? I don't have much money so I thought buying the part and repairing it myself might be better. Although I've never repaired one before.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi!
Sounds like your bluetooth chip died and need to be replaced.
It’s located on the Accessory Antenna Board.
Here is the guide to replace it: Xbox Series X Accessory Antenna Board Replacement
It’s not that easy to replace it if you don’t have any experience yet. Please check out the guide, here you can determine if you are confident to replace it by yourself or bring it to a repair shop!
You could buy the part here: https://a.co/d/5U8xs9h
这个答案有帮助吗?
得分 1
4条评论:
Awesome, thanks for the help! I'll get back to you when I have either fixed it myself or went to a repair place. I'll probably buy the part myself either way though 😆.
完成的
My pleasure :D! Alright, just let us know if you've fixed it or not (and when it's fixed). If you are going to repair it by yourself, good luck! No soldering is required, so this makes the repair somewhat easier :).
完成的
So, I finally put in a "new" Accessory Antenna Board. It worked...for a day. It's once again disconnecting my controller and headset. I guess I'll have to get a whole new console. Unless you guys have some other trick up your sleeve😅. The "new" board looked used, it had the Microsoft logo scratched off and some stickers missing, also some wear. I understand it was probably refurbished, but what if that's the problem. What if I need an actually new board, not refurbished.
完成的
Hi Karman! Hmm... Since it worked for a day, does say something about the Antenna board. It's possible that the Antenna board is having the same issue as your old one had. I would try to get a replacement again, to see if that will fix it...
完成的
添加一条评论
添加你的答案
Karman Wilmot 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 65
总计 423
