跳转到主内容
Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
Determine if there is a SATA SSD or Blade SSD installed
Hey fellow fixers!
I am trying to determine, prior to opening it up whether a late 2013 iMac has a Blade or 2.5 inch SATA SSD installed.
Essentially, this iMac had its original spinning HDD upgraded to a SSD, but I was not the tech who did that upgrade. Now I need to open it up to possibly recover data from the drive and I want to make sure I have the proper enclosure for the process.
I don’t know if the person who did the upgrade installed a blade type SSD or a 2.5 inch SSD.
Is there a way to determine this for sure in system information so I can be sure prior to cracking this thing open?
Thanks in advance!
@danj
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
If the system is still running, go into About This Mac and click on System Report. Now click in SATA/SATA Express and NVM Express tabs to see what is present for drives. Jumping to Storage gives you the volumes report.
这个答案有帮助吗?
得分 2
1条评论:
Thanks @danj
完成的
添加一条评论
添加你的答案
Milo (TechsMex) 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 140
