跳转到主内容
加入维修社区 - 创建账户
第四代高尔夫 (Golf Mk4) 于 1997 年 8 月首次发布,随后于 1998 年 8 月推出了三厢版本(大众 Bora,在北美地区再次被称为大众 Jetta),并于 1999 年 3 月推出了全新的高尔夫 Variant(旅行版)。
rear defogger doesn't work
How to fix it
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi @pedrogigante
Have you checked that the 25A fuse #26 in the instrument panel fuse box is OK?
The fuse box is located behind the cover on the driver side edge of the instrument panel.
这个答案有帮助吗?
得分 2
添加一条评论
if the fuse is OK, take a look at the actual grid on the rear window.
Sometimes, from wiping the glass, or objects rubbing against the glass, the line on the window, (those lines are the actual electrical resistors that warm the glass), will get a break somewhere.
It doesn't take much, because thos lines are just like a wire.
One break or missing stop, and the circuit is broken. Doesbn't work. Kaput.
If the break can be seen, you can get a bottle of resistive repair from the auto store. Just brush (carefully) the liquid on the missing spot, to re-complete the circuit. Don't get messy, or think that more is good. - It's not.
You just want to re-connect the line, (only) where the break or gap is. It usually takes only 1 tiny dot to do the job.
Good luck.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Pedro Gigante 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 300
