跳转到主内容
蘋果2020年的主流型號iPhone,其發布於10月23日,搭載6.1吋OLED螢幕及12MP雙鏡頭模組。其有著5種顏色,為iPhone11的後繼產品。
165 个问题 查看全部
Wired charging failing after battery replacement [wireless works]
I have followed the battery replacement guide from iFixit, using their kit.
The repair went smooth, screen did not crack nor did the battery explode upon extraction.
Once the new battery was installed I have charged it to 100% and drained it back to 0 with a wired cable according to the guide.
When I tried to charge it to 100% for the second time, it stopped charging at 20% and never accepted the wired charger again.
I have:
  • cleaned the ports
  • tried different outlets
  • tried several chargers
  • force restarted
with no luck.
The phone is able to charge wireless and there was no issue with the battery drawing power, so I would be suspecting some error with the port, caused by the repair. However, how did it work for the first day in that case? Also, this repair had nothing to do with the port itself.
Thanks for the read and hope you have some suggestions!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You probably just nicked something in the port, you could try to find anything wrong with the old one but I suspect the port
Here's a replacement port for the iphone 12
iPhone 12/12 Pro Lightning Connector Assembly图片
产品
$79.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
leonardofquirm 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 16
总计 16
