跳转到主内容
加入维修社区 - 创建账户
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
How to replace flash drive?
I opened up my late 2015 iMac 27 inch retina and was surprised not to find a physical hard drive. My computer crapped out last week after running flawlessly since I bought it new. Ended up with the blinking folder of death. I’m thinking the factory installed 256 GB flash drive failed, how do I replace? What kit do I need? Can I also run a second SSD drive?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
If your system came with a SSD then you need to follow this guide 27英寸 5K Retina 显示屏 iMac 固态硬盘SSD 更换
这个答案有帮助吗?
得分 0
8条评论:
Thank you, but it did not. Include an SSD or fusion drive only a flash drive.
完成的
Opened up and no Hard drive. I guess it only has flash?
完成的
@lovemyimac - A Fusion drive uses both drive ports! It’s not a single device it’s two: The SATA drive and the PCIe Blade drive.
As you stated the SATA dive was not present, that only leaves the blade drive which can be by it’s self.
完成的
@danj so the blade drive is what I need to replace then? Originally I ordered with a 256G drive. Can you recommend what products I need to get this computer back up and running?
完成的
@lovemyimac - In iMac's I always recommend pin compatible drives like the OWC Aura Pro X2 SSD as its a lot of work to go back in to dicker with the other options. I recommend going with a 1TB as the smallest.
完成的
显示更多的3条评论
添加一条评论
添加你的答案
LovemyImac 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 143
