跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2273 个问题 查看全部
Microphone Not Working iPhone 7
hello!
i got two iphones 7, one jet black iphone in prestine condition but it had icloud lock on it, i wanted to check if all the parts worked on it cause i got another one, a black 128gb one without icloud lock on it, on ios 14.3 but with a cracked screen and supposed with not working microphones
i changed the screen with the home button, front camera assembly succesfully, changed the housing with the jet black one cause this one had more scuffs on it and i loved the jet black one
during the transfer i didnt transfered the charging port cause on the jet black one the microphones worked perfectly but everything to no avail
can it be the audio ic chip on the motherboard? the loudspeaker and ear piece speaker are working perfectly, they were before but the old one had a lot of dust near the crack which was around the bottom right of the screen, below lcd (an actual hole)
i mention that any lightning to jack adapter isnt registered, everything except microphones are working as they should
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
probably is an audio ic issue
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
alex 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 34
