跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2266 个问题 查看全部
My home button got too much isopropyl alcohol
In order to lift the home button off the broken screen, I had to pour some IPA 99% to unbind the adhesive.
But I may have used too much and some of it may have entered the home button.
As a result, Touch ID works, but clicking doesn't.
Is there anything I could do to fix this? Maybe using heat, and introducing something inside the home button to "unclog" it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I'm not entirely sure if this will help, but I ran into a similar issue with the button on an iPhone 6 that I had repaired. It wasn't clicking unless you pressed really hard on it and I eventually figured out that in the process of removing it I had knocked off the little rubber nub in the very center that transfers the button press to the little tiny domed contact.
To fix it, I simply found a thin piece of rubber and cut out a tiny square (it doesn't have to be round) and glued it on where the original nub had been and from then on it worked perfectly.
I don't know for sure if the later model buttons are close enough in design to the one on the 6 that the problem could be the same, but I'm thinking that the excess rubbing alcohol could have loosened the glue on the little nub and let it fall off without you noticing.
No idea if that's the problem, but worth checking I suppose.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Alex222 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 18
