跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2272 个问题 查看全部
Repaired lightning port but still not charging
One of the pins in my IPhone’s charging port Broke so I replaced it with a new port but it still won’t get a charge. Could this be a problem with the battery or something else? Is there any way I could troubleshoot shoot what is going wrong? Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi Jacob,
If you really want to go deep down the repair rabbit hole, then repair.wiki is the place for you. You'll want to pick up a USB volt/ammeter so you can tell how much power the phone draws, which will help pin down the issue, but go. read this article first.
How To Diagnose & Fix an iPhone 7 That Does Not Charge, Takes 0.006A via USB - Repair Wiki
As far as straight-forward repairs go, you've done the obvious and most likely one already and presumably tried a different charger and cable too. That really only leaves the battery as a possible source of problems before you go down the path of diagnosing board level problems such as replacing the Tristar power controller chip.
So yeah, the next obvious thing to do would be to replace the battery, and after that you're headed in deep.
Good luck and let us know what you find!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jacob Parness 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 38
