跳转到主内容
索尼 PlayStation 5 DualSense 手柄的维修文档。 型号: CFI-ZCT1W FCC ID: AK8CFIZCT1
20 个问题 查看全部
Playstation power button not working
I'm trying to become a bit of a hobbyist In repair and my friend has given me his ps5 controllers to try and fix. Two had stick drift which were very easy to repair. But this third controller is driving me insane. I have taken it to pieces. Cleaned everything yet the PS button in the middle never engages. I've cleaned all the contact. Checked the motherboard still nothing. I changed the battery which showed the charging light working but the PS button still didn't work. Is there a way to diagnose it? (every of a button works fine. I used steam controller test which is very good for me. It shows everything working fine except the PlayStation home button)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The culprits are: the button, the flex circuit sheet, the foam bar under the sheet, or the motherboard contacts. Try swapping out the circuit flex sheet with a known working one. Check the foam bit that presses the flex circuit up against the motherboard, if that foam is too squished or damaged it can cause loss of contact on any number of buttons. On the motherboard where the flex circuit presses onto the board check the graphite covered contacts and see if the trace is broken right where the conformal coating ends and the graphite begins. Even bits of filth can interfere, try a good (but gentle) cleaning of all the contacts with 91+% isopropyl.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Calum Cooper 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 32
总计 280
