跳转到主内容
蘋果2020年的主流型號iPhone,其發布於10月23日,搭載6.1吋OLED螢幕及12MP雙鏡頭模組。其有著5種顏色,為iPhone11的後繼產品。
173 个问题 查看全部
Dim screen after replacing with LCD
I replaced my screen on my iPhone 12 with an LCD and after I replaced it turned on with the Apple logo and it seemed bright and fine but when it goes onto the Lock Screen it was super dim so I tried to turn up the brightness and it didn’t fix it but instead it stayed dim. Why was it bright while turning on but now it’s dim and I can’t change the brightness?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I'm willing to bet this is related to the ambient light sensor. It's an issue I have seen myself with the iPhone 12. If the Ambient Light senor isn't working properly this is exactly the behavior you'll get. Apple logo is maximum brightness, because it's always maximum brightness. But once the lock screen shows, the ambient light sensor kicks in. If it's not working properly, then the screen will always be at minimum brightness.
Did you transfer the sensor/receiver speaker cable from the old screen? If so those cables are very delicate and it's possible it was damaged. It could even have been damaged beforehand if the old screen was damaged in that area. I could give it a good inspection. The iFixit Guide even calls this out in this step of the screen replacement guide.
If the new screen came with a new sensor cable, it could just be that the ambient light sensor is a dud.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Nathan Williams 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 32
