跳转到主内容
索尼 PlayStation 5 DualSense 手柄(第一代)的维修指南,拆解信息和支持文档。本产品型号为 CFI-ZCT1W,主板型号为BDM-010。DualSense 系列手柄取代随 PS4 同期发布的 DualShock 系列手柄。
R1 does not register or is constantly engaged
I have 3 controllers where the R1 is constantly engaged or unresponsive (depending on the sequence of turning it on). I took apart all 3 controllers and even swapped trigger modules from the left side, the issue remains. There is no damage to the ribbons as I was able to put the Right trigger module on the left side and it worked.
My best guess is either 1) Motherboard issue or 2) Softeware bug (however there have been no updates recently). I am finding it hard to believe that 3 of 4 controllers went bad at the same time and it not being software (firmware) related. THERE IS NOTHING on the internet and I feel like I'm crazy.
Any ideas or at least how I can recoup some costs because otherwise the controllers are in fantastic condition.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I had one come through that was acting really odd, various symptoms regarding button presses and also intermittent loss of bt connection. When tested in windows it was not recognized as a dual sense controller, it was considered "generic". I did a full re-ball on the main chip, solved everything, there were oxidized pads under a few of the balls on the main board.
Loss of just the R1 is odd though. Have you done a factory reset on them? The main suspects: plastic button, rubber part, ribbon, connector on board, and then any components or traces from the connector through ultimately to the processor chip.
Personally I'd take an entire right side model from a known working controller and swap it in. If the known working right side module doesn't work then for sure the problem is on the main board somewhere between the boards connector and the main processor.
这个答案有帮助吗?
得分 0
2条评论:
Yeah seems to be something on the main board for all 3. Thanks for the response. I was hopeful with the latest firmware but alas, R1 is still constantly engaged.
完成的
My dualsense also started this issues whereby r1 respond sometimes and stops responding, been going through this chat to see if there's a solution to this. I have updated the console system software to latest version but the issue with r1 still persist. Do i have to update the controller software separately. While when I check it says the controller is in the latest system software update.
完成的
添加一条评论
添加你的答案
Bob 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 64
总计 892
