跳转到主内容
Apple 发布了 MacBook Pro 15 寸配备 Retina 显示屏,拥有 2880 x 1800 分辨率。
LCD replacement; is EEE important?
I broke the lcd of my macbook pro 15 mid 2015. I'd like to buy a donor (also mid 2015) and replace the screen. But I cannot know the EEE code of donors lcd beforehand. So, I'd like to know if the EEE code is important here or they are interchangable(assuming that donor is also mid 2015). Thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@danj Thank you for clarification. Today received donor macbook that I ordered and replaced the screen of my broken onc. Works like a charm
完成的
添加一条评论
1个答案
已选择的解决方案
The EEE code would only be needed when working with a raw LCD panel. If you are working from a complete display assembly then that’s not important, but the match up of the assembly to yours is.
If you have a mid 2015 15” MacBook Pro then the Apple P/N is 661-02532 for the assembly. As this series was very popular and it also have issues with the Anti-Glare coatings there are very few displays available and only salvaged ones and people who have them aren’t eager to give them up!
So be careful a good one is around $500 USD
Here’s the guide to install it 2015年中视网膜屏macbook pro显示器组件更换 and here’s one source TheBookYard - UK
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Andrey A. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 235
