跳转到主内容
加入维修社区 - 创建账户
2021年10月发布的14英寸MacBook Pro的维修指南和拆解信息,该产品采用苹果设计的M1 Pro和M1 Max SoC,型号为A2442。
Is this battery damaged?
I opened my macbook to check, the logic bord has 0,0 issues.
But my issues having was the wifi, airdrop, bluetooth not working.
At a certain point it got stuck while playing 4k videos.
And the screen wasnt working.
Now I opened it and all batteries(which were functioning properly btw and the logic board aswell I assume?(latter i do not know for sure due to the fact I dont know where airdrop, wifi et all are)
Ive added a picture of 1 battery. It seems surface. At first I thought it was some waterdamage because the underplate had some stains. Hope you know any advice.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Well... Yes your battery is not healthy! As it has become swollen! The BMC logic or a bad battery is at the root of this issue.
It doesn't explain your other issues! Be it WiFi or Bluetooth not working (airdrop leverages these) as well as getting stuck while playing 4k videos.
I would install a good thermal monitoring app like TG Pro and to monitor the battery health I would have installed this Gem! CoconutBattery
While you've already disassembled I would just replace the battery at this point MacBook Pro 14" (A2442, A2779, A2918) Battery following this guide MacBook Pro 14" 2021 电池替换
Replace a 6068 mAh A2519 battery compatible with the 2021 MacBook Pro 14" model A2442 or 2023 models A2779 and A2918 laptop. 69.9 Watt Hours (Wh). 11.46 Volts (V).图片
产品
$99.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Larry van Doorn 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 12
总计 129
