跳转到主内容
Apple的9月20日发布的Apple主流2019 iPhone带有6.1英寸LCD触摸屏,双摄像头和六种可用颜色。iPhoneXR的后继产品。
478 个问题 查看全部
Reasons behind black shadows on screen
Hi, recently I’ve agreed with my friend to buy his iPhone 11, and we agreed that I will give him money after some time.He didn’t say anything about the black shadows on the screen. I know it is a backlight problem. My concern is that I started noticing that the display on the iPhone has spots where there are black shadows which don’t go away or anything like that. I would like to know if it was my problem that it started appearing. Could it be caused by water damage, or what is the reasoning? I’m attaching 2 photos. One shows an example of the shadows (not my photo), and the other shows original photo of the display, if any of you can edit the picture that way, that it shows if the spots are there or not. Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @exportrecords
Check if the liquid contact indicator in the phone is showing any evidence that water may have penetrated the phone.
If that is clear then it could still be liquid damage but not near the indicator or simply that the screen has failed for whatever reason - phone dropped, excessive pressure on the screen at that point causing internal damage etc.
As the screen will most probably have to be replaced, here's the ifixit iPhone 11屏幕更换 guide. Take note of the instruction in the guide regarding "The combined earpiece speaker + sensor assembly affixed to the back of the screen is paired to your individual iPhone at the factory, ...." when doing the replacement.
这个答案有帮助吗?
得分 1
2条评论:
Hi, does it get worse over time ?
完成的
@exportrecords
Hard to say.
One thing for sure is that it won't get better.
Did you hand over the money before seeing the phone working?
If it was like that from the time that you got it, perhaps renegotiate the payment as I think that the screen will have to be replaced perhaps sooner than later.
完成的
添加一条评论
添加你的答案
EXPORT Records 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 17
总计 57
