跳转到主内容
苹果公司的 2021 款 iPhone 于 9 月 24 日发布,配备 6.1 英寸 OLED 显示屏、双 1200 万像素摄像头系统和五种可选颜色。该手机为 iPhone 12 的继任者。
95 个问题 查看全部
Charging port clogged with debris, possible bent pins
Picked this up for cheap second hand as it had issues with charging, after looking at it there seems to be some sort of thick debris in the charging port which I think may be the root of the issue, a lightning connector doesn’t go all the way in, it doesn’t “click” like it would with a clean phone, after looking closer I’m thinking there may also be bent pins and this May be a full Charing port replacement.
If it’s just debris should a tooth pick / Compressed air do the trick?
The phone powers on and work perfectly, and can charge through wireless charging, it’s just the lighting port that is the issue
I will attach images of the port as I’m not 100% sure if they are bent or not
any help is appreciated :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
I'd power the phone off and pick away at the debris with a small needle or a thin piece of plastic. Over time, dust seems to have been compacted at the bottom of the lightning port, preventing the charger from going deeper into it and clicking/latching on properly. You could also carefully drip some high-purity isopropanol into the port to help unstick the compressed residues.
There seems to be a good chance of it working well after that, and a charging port replacement seems to be unnecessary.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
AnAceCase 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 12
总计 54
