跳转到主内容
Why only two LEDs on my computer are lighted
I acciently pluged 220V, and the power supply bombed... and I replaced it with a good-working one. But only LED1 and LED2 are lighted, fans aren't worked, and only harddisk is still working. I tried three different RAMs and I'm sure Ram is OK. What's the problem???
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
10条评论
@highsheep have you had a chance to look at the logic board yet? Time to tear it apart and check for damage. There are plenty of capacitors that will take a hit on the 220V. Might be time to recap the beast anyway. We really need to see this board to assist you with that. Luckily schematics and board views should be available, we just need to know what your exact board number is. I suspect a 820-1540 All you have to bring to the table are the soldering skills and obtaining components :-)
Once you have your board removed. Take some good pictures (top and bottom) and post those with your Question. That way we can see what you see. 在已经存在的问题里加入图片
完成的
@oldturkey03 I put my pictures below
完成的
@highsheep I guess it turned out to be a 1540 and they promptly place a sticker over it :-)
完成的
@highsheep you will need this for sure. LB# 820 1540 Start with the power block diagram and see if you get a feeling for it. Then take a look at all of the power rails (focus on page 7) Inductors and voltage regulator love to get destroyed in overvoltage situations. Anyhow, you will have to be okay with reading schematics, and basic testing of components. We can always assist but you are the hands, eyes and ears of this operation ;-)
完成的
@oldturkey03 Thanks, I'll have a try
完成的
显示更多的5条评论
添加一条评论
1个答案
已选择的解决方案
Ouch! Sounds like the logic board got hit as well.
Not much you can do here, either replacing the logic board or if you have the skills fixing the damaged circuits within it.
这个答案有帮助吗?
得分 1
3条评论:
Acutally I want to fix it by myself, I really enjoy the process. Can you give me some tips about it?
完成的
@highsheep - you’ll need to surf the web to find the schematics and board drawings so you can ID the components and the voltages of the power rails to help narrow down things.
If you look at the logic board you should find it’s number it typically starts off as 820-???? Use that to search by.
完成的
@danj Thank s fir your help
完成的
添加一条评论
添加你的答案
Highsheep 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 25
总计 226
