I want know about screw size
I have change the battery but lost the internal battery screw please tell the size of screw which put on Battery have change the battery but lost the internal battery screw please tell the size of screw which put on battery.
@abhisheknandan your battery should be fastened by two captive screws that are on the battery. Are you referring to one of those screws?
由 oldturkey03 完成的
@oldturkey03 yes the two captive screw. What are there size where to buy or get full details
由 Abhishek Nandan 完成的
@abhisheknandan should be either a 2.5mm or a 3mm screw. Try one from the bottom cover. those are 2.5mm screws. Does it go into the screw hole without forcing it? Then it is a 2.5mm screw. Most good hardware stores do sell the smaller metric screws. get a few different sizes until you have one that fits.
由 oldturkey03 完成的
