跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
915 个问题 查看全部
My home button does not push in
I'm sorry if i have terrible grammer,
but i need some help here. My Ipod Touch 4g seems to be splitting apart (silver casing from touch screen) and has been progressivly swelling (or so it seems) and i can no longer push in the Home Button at all. help?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
if the front is coming away from the rear case then the home button will not be able to make contact with the logicboard. You need to open the ipod fully and find the cause of the swelling..perhaps it has been dropped and split the seal, or more unlikely the battery is swelling and pushing the display up. Either way opening the device and repairing the problem is the only solution here-you shouldn't need a new home button, it will work again once the front is secured to the rear.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jonah 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 959
