Is any way to detect the vinyl board so I can change him?
Hi, I think there was voltage jump.. so my vinyl stoped working.. just show red lamp and turns of.. I tried to find same plate but I can't find this..
Maybe you can help me to detect the right plate?
My vinyl model is SAFA CA-4004
Thank you very much
Hi @yaniv73744,
If there's a power board in the turntable, i.e. where the power cord connects to, post an image of it.
If there has been a power problem then most likely the power board has been affected first, before the control board.
I think that the image you posted is the control board, is this correct?)
由 jayeff 完成的
@jayeff looks like it has a barrel connector on the front. Maybe it uses a AC power transformer to power up.
@yaniv73744 any chance you can provide a component side picture (outside of the drawer) of this board? What happened to it (left top corner looks scratched) or maybe its just my old people vision playing tricks :-)
由 oldturkey03 完成的
@oldturkey03
You've still got better eyes than mine ;-)
Zoomed in I can see DC +12 on the board behind the connector location.
AC/DC power adapter used to connect power to the turntable, maybe?? If so perhaps that should be checked first for correct voltage out of the adapter..
由 jayeff 完成的
