跳转到主内容
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
427 个问题 查看全部
No backlight but has display. Might've found possible reason
Greetings, this is my first time posting on iFixit and the first time I was able to get a hands on an Apple product such as a Macbook Air A1466. This was given to us by a friend and stated that it was left near the restroom so it might've gotten some water damage.
After receiving the Macbook, I immediately tried to see if there's a display even without the backlight but sure enough there was. I disassembled it and found a corrosion of those small SMD resistors around a small chip.
I tried to clean the corrosion but due to the severity of it, I accidentally tipped two of the small SMDs. I wanted to ask if what part are those and are there specific types for them.
I hope all of the files I uploaded be of help. Thank you very much.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
@gabzloadea30346 watch the orientation of the two missing resistors. They go vertical not horizontal.
Reference designator R7715 is a 100K 1% 1/20W resistor in a 0201 package
Reference designator R7731 is a 200K 1% 1/20W resistor is a 0201 package.
Nothing special about those and most electronic supply houses should have them I am partially to Mouser.com or Digikey.com but you can get them from wherever you can get them from, :-)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gabzloadead (Gabzloadead) 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 15
总计 51
