跳转到主内容
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
Why wont my switch turn on after water damage and I tried fixing it
Nintendo switch fan comes on when I connect the battery to the motherboard but it doesn't show anything on the screen and I tried it with a dock and nothing happened.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
If your Switch is refusing to boot due to corrosion, then I believe that the motherboard is broken (along with some other components within the Switch). Sure the fan may come on, but that doesn't mean that some other component of the motherboard is still broken. So I would suggest a motherboard replacement, a guide on which can be found here (unless you can clean it somehow, which I talk about below): 任天堂Switch的主板的更换
Other components of the Nintendo Switch may have also been damaged, such as the display or some other daughterboards (e.g. the MicroSD card reader), so I would recommend checking them for any corrosion, which can be cleaned up using this guide: How to Correctly clean corrosion from a MacBook Pro logic board. (I know it is for a MacBook and not a switch, but the processes are basically the same for the Switch)
If you are unable to clean up the corrosion, you can simply purchase replacement parts here: Nintendo Game Console Parts
Do note that this sort of repair may be rather costly and take a lot of time, so if you do wish to carry out this I do wish you the best of luck with it.
MacBook Pro图片
指南
难度:
中等
2 hours
Nintendo Switch 主板图片
指南
任天堂Switch的主板的更换
难度:
中等
1 - 2 hours
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Julian Valentine 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 22
总计 248
