跳转到主内容
The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
85 个问题 查看全部
TI-84 Plus CE My calculator says: Validing OS calculator will restart
My calculator says:
Validing OS
calculator will restart when validation complete. And starts blinking over and over again and I cannot fix it, I tried to charge or reset it and It doesn´t work.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
This issue is more common with newer TI-84 Plus CE calculators. Sometimes they won't charge dead batteries. You can try charging the battery in a friend's calculator or get a replacement battery.
If your calculator is within warranty, you can contact TI Cares and they may send you a new battery for free.
这个答案有帮助吗?
得分 1
添加一条评论
Try the following as they seem to be the most likely cause:
  1. Remove the battery and let it sit for ~10 minutes, reinsert the battery and see if it resolves the issue.
  2. Replace the battery, it seems the most common fix is ordering a new battery, here is the link to buy a replacement battery from Texas Instruments (far cheaper than Amazon) https://epsstore.ti.com/OA_HTML/ibeCCtpI...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Samuel Verdugo Peinado 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 24
过去 30 天: 126
总计 542
