跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1202 个问题 查看全部
Why is my iPhone starting to heat up when I plug in a new battery?
Hi all, I have a problem with my IPhone X. It wouldn't turn on after overheating. This happened after I tried a few power adapters plugging in and out to test the plugs/cables (not clever). So it overheated - became extremely hot and I struggled to hold it then I put it out in cold weather and it cooled down and would not turn on. So I decided to change the battery, I have experience in taking phones apart so it wasn't an issue. I stuck in the battery and when I reconnected one of the battery plugs it immediately started to reheat on the right by the power button components - it seems that the phone isn't dead entirely. Would it be worth for me to replace the power plug ( charging port) or anything else?
I will leave it unplugged for now as I know it is a hazard. Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Ok ok ok ok ok ok ok ok ok
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rose P 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 23
