跳转到主内容
Model number: 20R1000RUS, Released in June 2019
11 个问题 查看全部
Lenovo x1 carbon laptop not turning on after a fall.
I am trying to fix a relative's laptop that fell and crashed to the ground. No visible signs of damage except one crack on the power button. When connecting the charger the charge indicator turns on normally, and the power button blinks 3 times as usual, but won't turn on. Already tried replacing the daughterboard to no results.
Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
You will need to open it up and check that all connections are good including CPU, GPU, hard drive, reseat RAM modules, Wi-Fi, screen cables, etc.
Hardware Maintenance Manual
Have you tried the Reset option with a paper clip? Go to the explaination here:
Why does my power button blink 3 times?
这个答案有帮助吗?
得分 2
1条评论:
I already opened it up but all the above are connected to the motherboard, how can I check the connection? The multimeter wasn't very helpful due to the very fine nature of the contacts.
完成的
添加一条评论
添加你的答案
George Andreou 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 51
