跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
no sim card error
friend may have dropped phone top of phone plastic cracked around sim card holder and part of top of sim card holder at the eject hole. I tunes and phone try's to activate the phone but no sim car error in i tunes and phone just ask's to try again. I don't have service i just want to reload the phone with software so I can use wifi
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Sim card is not pushing on the sim detect switch at the back of the sim card tray.
Temp solution remove sim tray edge and insert sim tray.
这个答案有帮助吗?
得分 0
添加一条评论
I had the same problem and tried several times with different sim cards. Still didn't manage to get it started. Is there anything else to do?
这个答案有帮助吗?
得分 0
1条评论:
Did you check to make sure that the sim card readers pins are still making contacts and did you clean them? Did you check the sim card detect switch at the back of the sim card slot? you might also want to check on here http://www.youtube.com/watch?v=tdE6zGTsF...
完成的
添加一条评论
添加你的答案
jeffreyclark1981 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 6,855
