跳转到主内容
发布于2011年7月21日。Core i5或Core i7处理器。雷电(Thunderbolt)接口。本机也用于Mac mini Server配置。
Three beeps at startup after disk upgrade on a Mini Server
After upgrading the two disks, my mini server won't boot : I have 3 beeps at startup apparently indicating a memory problem. This is not solved by replacing the memory modules by two others.
I've then replaced back the disks by the original ones: the mini boots perfectly with either sets of memory modules.
Is there anything to be done to prepare the disks before installation?
Has anyone experienced that?
Any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
What are the makes and models of the new hard drives?
完成的
添加一条评论
1个答案
已选择的解决方案
Take out ALL RAM - you should get a blinking light which indicates no RAM selftest pass ok. Replace the RAM try to boot with ONE new disk - (of course you did format the new disks and install OS). Proceed from there.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
LHR 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 1,523
