How can I trick my fridge to stay on while in an unheated garage?
My ge fridge is in my unheated garage and it stops cooling all together when it's too cold. It does turn back on for some strange reason if I unmount the temperature control panel in fridge part it starts to run after a few minutes....what is going on?? I took apart upper freezer portion and no frost, electric coming to the motor, clearly this works but how can I heat the temp sensors into thinking it's 40 degrees outside of the fridge
5条评论
@giuseppetirone what is the temperature inside the garage?
由 oldturkey03 完成的
Garage gets cold as outside, running a heater next week to my panel but for now I have lots of stuff I don't want to spoil
由 giuseppe tirone 完成的
Hi @giuseppetirone
What is the model number of the refrigerator?
由 jayeff 完成的
It's a ge model GTS22IBMBRWW. Top freezer. Temperature sensors inside right for freezer section and fridge section. I'm trying to figure out where I would put the heat pad for my model.
@giuseppetirone
Not sure about a heat pad as the idea is to warm up the refrigerator compartment enough to turn on the compressor to make sure that the freezer compartment is cold enough.
With a heat pad the temp sensor may keep the compressor running all the time as the temp in the refrigerator may never get low enough to stop it i.e. if too close to the sensor unless you had the pad on a timer. The heat pad on/off time would have to be sorted out though
Perhaps having a 10W light bulb on an extension cord in the refrigerator compartment may warm it up slowly enough so that the compressor turns on for long enough each time and keeps the freezer at the correct temp. You don't want to have to run the compressor more often than necessary.
由 jayeff 完成的
