跳转到主内容
加入维修社区 - 创建账户
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
Weak Signal after replace LCD Display
I changed my LCD assembly, just after that my iPhone have a weak signal o lost signal (no service), think i don't replace the screws at same order. Somebody help me ..! Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
5个答案
已选择的解决方案
Please refer to my earlier post here.
Accepted Answer
Included are images of correct screw length needed.
Good Luck.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Hi, look carefully at this thread
wi-fi distance was reduced
and look at the pictures. It is common to forget that small silver piece which gives contact to the wifi. Let us know if that helps!
~asle
这个答案有帮助吗?
得分 1
添加一条评论
check connector #7, place a tape on it just to make sure it's connected properly
这个答案有帮助吗?
得分 0
添加一条评论
There is a little metal piece "clip" next to the battery connector, Also called the pressure contact. These clip has a small pin that has to be bent in order to touch the back cover of the phone. If not you will have a "No carrier" issue.
Cheers
Erik
这个答案有帮助吗?
得分 0
1条评论:
[关联产品丢失或禁用: IF182-023]
完成的
添加一条评论
try a restore ! even if is the hardest way it works every time
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Georges 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 12,044
