跳转到主内容
13 英寸 MacBook Pro 于 2020 年 11 月发布,配备 Apple 基于 Arm 的 M1 SoC,具有 8 核 CPU 和 8 核 GPU。(型号 A2338 / EMC 3578,带有两个 Thunderbolt 3 端口)
116 个问题 查看全部
Are A2251 and A2338 screen Compatible?
Hi, my MacBook’s screen got cracked, and I’m searching for a replacement. However, every screen I’ve seen on eBay is labeled as A2251 And A2338. I’m unsure if it will work for me, considering one is for an Intel Mac and the other for Apple Silicon.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
To be clear the A2251 is a four port Intel based system and the A2338 is either the M1 or M2 system.
Sadly, Apple alters things between the series that prevent using older displays on newer systems.
The reason you can’t find a display for your M1 system is Apple has now entered into the open parts supply! While that is good for thoughts who want real Apple parts that are fresh. Apple also has tightened things require calibration via a pay-walled tool. While a used screen can be used you will loose TrueTone services. Review the iFixit guide here 2020年末期带两个Thunderbolt端口13寸MacBook Pro 显示屏总成更换
So you’ll need to visit Apples Self Repair Store to get the new display.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Santiago U 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 28
总计 105
