跳转到主内容
Repair and disassembly information for Samsung's Galaxy A13 Android smartphone, released in March of 2022.
108 个问题 查看全部
Phone won't turn on, but vibrates every 7 seconds.
Hi, as the title says, my Samsung A13 won't turn on at all. Continuously for 3 hours it has been making a single vibration pulse every 7 seconds. I'm kinda stumped as what to do. The screen is pretty cracked, so I would have assumed the screen was just dead if not for the vibrations, but that makes me wonder if something else might be wrong. The vibrations continue whilst on charge as well. The only time it stops is if I hold down the power on and volume down whilst charging. Has anyone else had a similar issue? Is my phone dead or can this be fixed?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
@valenciyaaaaa start by replacing your screen. Your phone vibrates because of a broken display. Once you have that fixed you can check and see if A. the vibrations stopped or B. if this is just a bootloop related to other issues. Again, screen first then re-evaluate.
Since iFixit does not yet have a guide for this, use the one from here Replacement screens are readily available and not to expensive.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
valenciyaaaaa 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 30
总计 124
