跳转到主内容
seeking enclosure for SSD from MBP early 2011?
Hello - I have an early 2011 MBP that has a 1tb ssd upgrade, I would like to remove the ssd and use it as an external drive, but not finding a compatible enclosure, is there one? I found this but it seems to be perhaps only for the SATA drive being removed in the upgrade... MacBook and MacBook Pro (Non-Retina) SSD Upgrade Kit --thanks much!
Upgrade the storage and improve boot time and read/write speed in your MacBook and MacBook Pro (Non-Retina) with this SSD upgrade kit.图片
产品
$72.99
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The case is designed for a 2.5” SATA drive not the blade SSD if your system has that.
这个答案有帮助吗?
得分 1
1条评论:
oops - Thanks Dan, I thought this one was an SSD but just pulled it out and it is a SATA. so perhaps it will work?
完成的
添加一条评论
添加你的答案
Ali-A. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 107
