跳转到主内容
The Kodak EasyShare Z740 offers an impressive feature set, easy-to-use controls, and a powerful zoom, making it a good choice for anyone looking for a simple camera with room to grow.
Kodak EasyShare Z740 wouldn't turn on.
About Kodak EasyShare Z740.
I haven't used it for a long time. I read on a blog that you can use regular AA batteries, so I inserted two AA batteries and turned it on, but it still wouldn't turn on. Does it need repair?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
This question was migrated from https://meta.ifixit.com/Answers.
完成的
添加一条评论
1个答案
@cbhub7xx8xbyg2r make sure that you have good batteries. If it still does not come on, you will have to check the fuses on your main board. There are 3, labelled F1, F2 and F3. F1 should be the power fuse. Check all fuses for continuity. F1 and F2 are 1.25A, F3 is a 2.5A fuse
Use these guides Kodak EasyShare Z740 to work on your camera. There is none specific for the main board, so you will have to "experiment" a bit. Lucily the easyshare cameras are all pretty similar. Between the Z650 Kodak Easyshare z650 Teardown and the Z710 you should get this accomplished without to much trouble.
Post some good pictures of your boards etc with your Question. That way we can see what you see. While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
在已经存在的问题里加入图片
Kodak Easyshare z650图片
指南
难度:
中等
45 minutes
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
小池勝 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 108
