跳转到主内容
Vavle 公司于 2022 年 2 月 25 日发布的游戏掌机。
255 个问题 查看全部
Fixing stick drift from water damage?
Recently spilled my whole water bottle on my steam deck. Made the dumb decision to turn it on but turned it off after. Used keyboard duster to spray as much water out as I could, I let it sit in front of a fan for an hour or two. Turned it on and there was horrible stick drift and the track pads were making terrible noises. I left it in a bag of rice for 24 hours which worked (somewhat). But the stick drift is still a problem and I have no idea how to tell if I need to get the track pads replaces aswell. Should I just get a whole new unit when I can afford one?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @homelotto
Using rice to fix water damage in electronic devices is a myth, it doesn't work Rice is for dinner, not repair.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the console's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your console and then remove the battery as soon as possible from the console to minimize any further damage.
Then you need to dis-assemble the rest of the device and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leace conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes what happens Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the console might possibly work correctly again.
Here is the ifixit Steam Deck guide that may help
If this process seems too daunting, take your console to a reputable, professional electronics repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
homelotto 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 27
总计 88
