跳转到主内容
The eighth generation of the Mitsubishi Lancer.
lights on the cluster flicker when I try to start it it all goes dead
I have a question hopefully some one can help me figure this out ! 2007 Mitsubishi galant the ignition was ok till now now I try to start it the lights on the cluster flicker the when I try to start it it all goes dead .the battery is fully charged don’t know where to start !! Does anyone had that problem with the ignition and knows how to fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @michaelgiovanni
Looking at the images of the starting circuit and some of the cluster lights, it seems that the only common factor may be a faulty ignition switch.
Once the ignition is turned to the start position the starter motor should begin to turn over as it is basically direct wiring from the switch via the transmission switch to the starter.
(click on image)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Michael Giovanni 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 130
