跳转到主内容
Guides for the Wi-Fi version of the iPad mini 5—model A2133. Released in March 2019, the iPad mini 5 is the successor to the iPad mini 4.
Digitizer not working after replacement
I bought a replacement Screen and digitizer The screen works great but the digitizer docent some spots don't register on the left and right in portrait mode and in regular mode I can't see ANY damage The connector looks good. Is there Something you have to cover or is it apple's prioritization
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
don't have the original screen but the old digitizer worked perfectly except it was cracked and the display
完成的
添加一条评论
1个答案
最有帮助的答案
You didn't mention if you had cleaned the connector with some 90% or higher isopropyl alcohol, but other than that it looks to me as though you've covered pretty much all of the diagnostic bases.
At this point I would communicate with the seller of the replacement screen on the issues you're having with it and see about getting a replacement, especially given that you didn't have digitizer issues with the original screen.
这个答案有帮助吗?
得分 1
1条评论:
thanks I cleaned it am waiting for it to dry. let you know if it works.
完成的
添加一条评论
添加你的答案
Alistair moran 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 157
