The electrical connector to the switch itself may be disconnected inside the handle.
After the obvious try a different outlet, verify the cord is plugged in both ends.
The connections to the illuminated switch in the handle are pressed on. After repeated dropping of the handle onto the floor, a switch connector may have fallen off the switch.
Unplug the unit and remove the screws holding the two sides of the handle together. Locate the loose wire and plug it back into the switch lug.
Loosely assemble the handle, plug in the vac and give it a try. If it turns on tighten the screws.
