跳转到主内容
加入维修社区 - 创建账户
Apple 2020年的顶级智能手机。iPhone12 Pro Max于10月13日发布并于11月13日发布,配备6.7英寸OLED显示屏,带LiDAR的三重后置摄像头系统和5G连接。iPhone 11的后继产品。 专业版
Software screen burn issue linked with IOS
I assumed the screen burn was due to excessive brightness on one static image that burnt the pixels in on this iPhone. I replaced the OLED and the screen burn is still there! Its a common issue in the new iPhone 15's and an IOS update was meant to fix it. I have tried restoring, flashing and updating. Nothing has helped. Has anyone had a similar issue and know of a fix, its quite frustrating that I now have a new screen that looks like its got a defect.
It is not a screen issue I have checked with another genuine display and it displays the same burn in on this one too. Seems to be programmed into the software. Anyway of wiping IOS completely and installing fresh?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Hi everyone! I bought the new iPhone 15 plus and it has been lovely. However, les got the same problem within 1 month after having it, noticed that the home bar and also the top indicators for the celular, WiFi and signal etc started to get slightly “burned” on the screen when dark mode is enable or every time those icons are displaying a white color.
After using Instagram, for example, for more than 10 minutes (or sometimes less) I can see those icons really visibly burned on the screen, being that after a while, it goes away, but never fully (this is easier to see against a grey background).
I wanted to know if this is normal behavior for an OLED panel, or if I had the bad luck of having a faulty screen. I also wanted to know if someone else has the same behavior on their iPhone. Thanks!
Ps- I also visited service center and give my phone for 7 days for test ajd they didn't find anything regarding this so they just returned my phone!
完成的
Hi everyone! I bought the new iPhone 15 plus and it has been lovely. However, less than 1 month after having it, I noticed that the home bar and also the top indicators for the celular, WiFi and signal etc started to get slightly “burned” on the screen when dark mode is enable or every time those icons are displaying a white color.
完成的
添加一条评论
2个答案
已选择的解决方案
I have managed to solve the issue but won't remove this question in case someone else is experiencing similar problems. This is what I have done that has worked for me
  • Make sure display connector is clean and installed correctly
  • Force restart phone
  • Update IOS through settings (17.1.2, Apple said this will patch this issue)
  • Try updating to public beta patch if regular does not work
  • Enter DPU mode and restore phone through itunes (My restore didn't want to download IOS firmware so I downloaded latest firmware from 3utools (17.1.2 in this case). Left click on restore whilst holding shift on itunes to open folder with system file. Continue with process.
  • Flash phone (Only as a last resort and at your own risk) I used 3utools
Always back up the device if you have important files/data before attempting
What worked for me in the end was the DFU itunes restore with the 3utools firmware, which booted with the same problem. I then tested a few displays on the phone (all which gave the same issue). I then put the replacement screen back and restarted which suddenly solved the issue. No more screen burn and I'm not 100% on what solved it but I can share the process which may help someone 🙂
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
The same thing happens to me, I have an iPhone 12 Pro in iOS 17.2.1 and it has the same problem, since previous versions. I compared with 3 other iPhone 12 and an iPhone 13 and they also have that problem, so it's not hardware but software. I don't know how Apple hasn't been able to fix this error. I hope you solve it in ios18
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Tom 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 63
总计 1,658
