跳转到主内容
加入维修社区 - 创建账户
Dell Latitude D820 发布于 2006 年 3 月 28 日,型号为 PP04X。
My computer won't turn on
When I press the power button on the computer, the computer does not turn on, but the control lights next to the power button turn on and blink for a minute and then the computer turns off
LED 1 is lit continuously
LED 2 and 3 are on alternately
Attached is a picture
I would appreciate an answer
Thanks in advance
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Hi @elchanan1
A blinking caps lock and scroll lock light indicates a motherboard problem (CPU?).
Try removing the ram and start the laptop. If there are no error beeps heard then the motherboard is faulty as ram is checked early on in POST (power on self test) so it hasn't even got that far when starting
Has the laptop been dropped or gotten wet at all?
这个答案有帮助吗?
得分 2
2条评论:
The computer did not fall or get wet
完成的
@elchanan1
I can only suggest that you download the schematic for the motherboard and check the voltages - see p.47 (CPU voltage) and p.48
完成的
添加一条评论
Have you tried another outlet? Or cable?
这个答案有帮助吗?
得分 0
6条评论:
I tried another cable and it didn't help
The same fault remained
完成的
There may be a power failure. It may be the motherboard or battery, both, or something else.
完成的
Could also be a corrupted OS.
完成的
I tried turning on the computer only when it is plugged in without a battery and still the same error remains
And it's not an operating system because the bios still doesn't come up
完成的
Have you tried to check the power button? It may be a problem with the case's power button
完成的
显示更多的1条评论
添加一条评论
My first thoughts:
https://www.dell.com/support/kbdoc/en-us...
Have you tried reseating the ram and swapping out modules one at a time?
Bad ram is so often the culprit.
Removing one module at a time, trying only one module, and then swapping them around after reseating them
might fix the issue or at least change your LED indicators.
Have you checked all your internal component connections yet (hdd, videocard, modem, CPU, ODD, etc.)?
It's remotely possible you might need to replace the cooling paste on your CPU after so many years.
If it's cheap and easy, I would replace the BIOS battery just for good measure.
Good luck!
这个答案有帮助吗?
得分 0
1条评论:
I already tried everything except thermal paste, but thermal paste should not cause such a malfunction
完成的
添加一条评论
添加你的答案
Elchanan Blumenfeld 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 22
总计 573
