跳转到主内容
The HP Compaq 8200 Elite is a small form-factor workstation-class desktop PC aimed at higher-end office and design work. It has a fairly repairable design with emphasis on allowing technicians to quickly swap out drives and cards.
When I turn on the pc, the fan is on but pc isn't booting up.
When I turn on the pc, the fan is on but pc isn't booting up. keeps making sounds with the fan
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
最有帮助的答案
@benancyber besides the fan, what have you checked? Start with the basics of your troubleshooting.
  • Check that the computer and monitor are plugged into a working electrical outlet.
  • Check that the voltage select switch (some models) is set to the appropriate voltage for your region (115V or 230V).
  • Check that the computer is turned on and the green power light is on.
  • Check that the monitor is turned on and the green monitor light is on.
  • Check the Power LED on the front of the computer to see if it is flashing red. The flashing lights are error codes that will help you diagnose the problem. Refer to Appendix A, POST Error Messages on page 246 for more information.
  • Turn up the brightness and contrast controls of the monitor if the monitor is dim.
  • Press and hold any key. If the system beeps, then the keyboard should be operating correctly.
  • Check all cable connections for loose connections or incorrect connections.
Download the service manual for your computer from here Start with the troubleshooting on page 260. Let us know what you find out.
这个答案有帮助吗?
得分 3
1条评论:
@oldturkey03 still not working coz i had already done all
完成的
添加一条评论
Hi @benancyber
Not sure when you say "done all" whether this included a full power refresh by disconnecting the power to the PSU and then accessing the motherboard to remove the RTC coin cell battery from the motherboard and then holding the Power button operated for 30 seconds?
If not try doing that. When the RTC coin cell battery is removed, measure its voltage. If it is <2.5V DC or the battery is >4-5 years old, replace it. The battery type is stamped on the battery itself. Usually they are CR2032 or CR2026 which are available everywhere e.g. supermarkets
Remember to reinsert the RTC battery (+ve on top as marked on the battery) and then reconnect the power to the PSU and turn it on and check if it starts OK.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
BENAN CYBER 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 37
总计 570
