跳转到主内容
A1706/EMC 3071—于2017年6月上市,这台13''MacBook Pro以可升级至3.5Ghz酷睿i7动态超频至4.0GHz的Kaby Lake处理器为特征。
277 个问题 查看全部
Right fan won't turn off after replacing USB C portd
Hello everyone, I just recently replaced all my USB C ports on my macbook. After puting everything backtogether and turning the computer on. I noticed that my right fan was constantly blasting full blast. I've tried resetting SMC and PRAM but I'm still getting the same problem. I also ran diagnostics and got an error code saying it was a problem with my fan. Could I have accidentally damaged somthing on my logic board? Or is this just a simple fan replacement? Thanks for your help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
If you have a multimeter, check for voltages on the fan connector to see you getting voltage. Best case scenario you just replace the fan itself and works again. Worse case scenario, you might moved the resistor or capacitor during the usbc replacement. Do a visual inspection on the board
这个答案有帮助吗?
得分 0
3条评论:
If it's running at 8000 rpm constantly it has to be getting power right? And what setting should I set my multimeter for?
完成的
I forgot to mention in my original post that I've tried using Mac fan controller to slow it down but it won't change the speed. The left fan will change just fine with the program
完成的
It looks like some of the pins are not communicating to the board and just receiving only power at full speed. Usual fans are 4 pins. But something is disconnected around board like a resistor preventing to communicate to the fan thus preventing you to control the speed
完成的
添加一条评论
@brettorenstein you sure it's your fan or is it possible that you are having other difficulties? The fan connection gets its signal through the keyboard connector. Check that cable, make sure the connector is not damaged and that the cable is properly seated.
Why did you replace the USB-C ports? What happened to the board. Let us know what error code you did get.
这个答案有帮助吗?
得分 0
1条评论:
Interesting to know. Thanks
完成的
添加一条评论
添加你的答案
Brett Orenstein 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 33
