跳转到主内容
2020年4月宣布和发布的第二代iPhone SE的维修和拆卸信息。
240 个问题 查看全部
iPhone SE (2020) restarts every 3 minutes
I recently dropped my phone and it now restarts every 3 minutes. I searched on the internet and have found several people with a similar problem but I'm not sure if I have the exact same one. I really don't want to buy a new phone and would appreciate any help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi Marc,
Well, I have good news and bad news. The bad news is the drop appears to have damaged your lightning port flex cable assembly, but the good news is it's fixable.
The panic log you pulled up gives us the vital clue we need to diagnose your issue right here.
According to the Kernel Panics Wiki page, sensor mic1 is located on the charging port assembly.
I'll give you a 90% chance that replacing the charge port assembly will fix the problem. Here's the part you'll need.
iPhone 8 Lightning Connector Assembly
Note that the 2nd generation SE is based on the iPhone 8 and retains much of the same hardware in exchange for an updated processor and motherboard, so the SE 2020 and the 8 use the same Lightning connector assembly.
Here's the guide to follow to replace your assembly.
iPhone SE 2020 Lightning Connector Assembly Replacement - iFixit Repair Guide
That should do it. Good luck on your repair, and let us know how it goes!
iPhone 8 Lightning Connector Assembly图片
产品
$24.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Marc Beckmann 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 15
总计 75
