Why isn't the battery working? I already replaced it with a new one.
Why doesn't the camera battery work, even though it has been replaced with a new one?
@agungpringgo the issue may not be your battery. The issue could be that the camera does not get any power. The first thing to check, would be the fuse that sits on the main circuit board, right past the battery connector. Check that one for continuity.
Use these guides Panasonic DMC-FZ70 to work on your camera. Once you get to the motherboard, post some good pictures of both sides of the board. That way we can see what you see and hopefully help you further. 在已经存在的问题里加入图片
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 21
@agungpringgo Do you have a multimeter so we can check the voltage of the batteries?
由 Andrew S 完成的
